Author Topic: head exploding wiring idea  (Read 6327 times)
JDC
« on: April 19, 2010, 03:45:28 AM »
so I been researching wiring and switching options trying to getting my head round it, rotary switches just made my head explode (might try at a later date) and SD tripleshots are a bit expensive when I'm just experimenting
I want to do this, but with 1 switch for both pickups, as I ain't drilling holes
now if my researching is right I would need a switch with 4 poles?
so it work with one of these?
http://www.wdmusic.co.uk/product/MINI_SWITCH_4_POLE_TRIPLE_THROW_CHROME_WDE8
Re: head exploding wiring idea
« Reply #1 on: April 19, 2010, 07:15:45 AM »
Quote
It is a combination ON/OFF/ON and ON/ON/ON switched rolled into one unit
not sure.   :?
hermetico
« Reply #3 on: April 19, 2010, 11:32:53 AM »
the schematic shows two DPDT switches with a centre 'on' position, you can get them from Allparts...
http://www.allparts.uk.com/online-shop/allparts-guitar-amp-parts/electronics/switches/mini-switch-dpdt-on-on-on-2-p-4058.html
+1
This switch (JDC) isn't clear if it's on/on or on/on/on. You need, for sure, a 4PDT on/on/on switch or a rotary 4PDT (single waffer, two poles).
Usually, bridge pickups don't benefite very much of parallel wiring, since this is the weakest ouptut mod in the weakest guitar's position but, a very high output humbucker can clean a lot with parallel wiring.
« Last Edit: April 19, 2010, 11:34:28 AM by hermetico »
« Reply #4 on: April 22, 2010, 01:14:29 PM »
+1
AAAAAAAAAHHHHH!!!!
reading the OP properly always helps - so he wants to do the parallel/split/blah-de-blah switching for both pickups using just one switch.
in that case, yep, you need a 4PDT switch, but getting an on/on/on version will be a bit tricky (if they even exist).
if anyone has one (or knows where to get one), it'll be Feline - give him a call.
JDC
« Reply #5 on: April 22, 2010, 07:58:44 PM »
cheers guys, found a 4dtp switch on allparts, out of stock!
was pricing up everything I wanted last night and noticed a review of that that WD switch, it wouldn't do what I want, so I'm going order what I need, order some BKPs, get all that sorted and working, then get a 4dtp switch
Neemo
    • http://www.mikseri.net/necessaryevil
« Reply #6 on: April 28, 2010, 10:59:10 PM »
Yes, that switch will work
slow music for slow people
