wanted middier Miracle Man
Started by wolfenstein, June 21, 2011, 07:22:03 PM
wolfenstein
Hi to everyone...I got MM for my all mahogany Viper and I´m realy happy with tone..It sound acurate when I play through my Krank Revolution+ head because it has ton of mids and it´s bright and chunky...I want next BK humbucker for my another guitar which is all mahogany as well but I use it often with my other amp Framus Dragon which is quite dark..So I´m looking for pickups with nearly same character as MM but with more mids...I play mostly HC/Thrash/Death stuff and I love chunky palm mute rifs like S.O.D...Anthrax...Exodus....I think that Aftermath or Painkiller but you know..I need some help....Thank you....
have CWP,MM...had AM,CS,VHII,NB,PK,HD...
Simply have an alnico V magnet in a Miracle Man  instead of the Ceramic and the mids will be much higher with less bass and a little less treble.
In fact you could just use a neck position MM in the bridge as it is pretty much the same spec winding.
Madsakre
Quote from: FELINEGUITARS on June 21, 2011, 07:53:19 PM
i want one of those too xD
Cattlepress
Emperoff
I actually asked Tim about that and said that the neck MM for the bridge would be "too sweet and polite" for agressive styles.
wolfenstein
Hm..Alnico..I have tried before alnico Nailbomb and I wasn´t very impressed..Too dark for my taste..I like heavy sound clip of Holy Diver but it wouldn´t work in mahogany.I would better stay with ceramic..What you guys think about Aftermath in dark mahogany guitar?
Transcend
The aftermath works very well in mahogany.
however it isnt like the miracle man.
its very dry and middy with considerably less bass & high end.
It is a very balanced clean & precise sound that is not as saturated as the miracle man.
I asked Tim about getting a custom pup that had the aggression & snarl of the MM whilst retaining the lows & highs but having the mids and precision of the aftermath and he said i had just described the painkiller.
I prefer it in basswood to mahogany though i feel it has a lot more grunt.
What i do with my MM equipped mahogany guitar when i want more mids is either turn the mids up
or use my ts808 to boost the mids and cut the lows some.
The high end on the MM alone should be perfectly fine for a dark amp.
Alex
Maybe a ceramic Nailbomb, although I haven't tried that pickup.
wolfenstein
Quote from: Toe-Knee on June 21, 2011, 08:58:43 PM
Maybe I shoud go for Painkiler..As someone said PK is oposite of MM in therm of mids..
MM-lower mids
PK-upper mids
Transcend
Yeah i can't say whether you should go for the PK as i havent tried it personally
it is on my list though
Nolly
Pretty sure you want a Painkiller, from what you've described.
schantist
If somebody described the PK to me like that, I'd want one too for the first time...
a lot more sense in that than in the ususal "Painkiller...  piercing upper mid, djent, djent, djent" talk.
wolfenstein
Quote from: schantist on June 22, 2011, 09:12:23 AM
Yeah..That´s reason why I wasn´t 100% sure about Painkiller because I know that some people don´t like his sharp highs even thin sound....But it´s always summary of factors as guitar body material,amp,speakers etc....I think that it will work properly in my guitar....
Madsakre
imho, the painkiller begins to shine when you tune lower, due to the tight bottom end. Its a tad too much in std tuned guitars. From C and below its just godly.
Cattlepress
Transcend
yeah the usual talk is the reason why i still havent owned one today it just puts me off
llJasonll
"imho, the painkiller begins to shine when you tune lower, due to the tight bottom end. Its a tad too much in std tuned guitars. From C and below its just godly."
I have to agree with this.  I have a set of painkillers (my first BKP) in a Mahogany body, super-strat, with a maple neck and rosewood fret board.  I use to tune it to C, but now to B-standard; and it sounds very godly!  Especially when the speakers on my cab start to break up.
If you tune to C-standard, I think you will really like the painkiller.
