Author Topic: New Amp Build Project  (Read 8416 times)
« on: October 08, 2011, 12:51:59 AM »
No photos yet...
I'm picking up an old amp with a similar layout to a super lead.
2 input, 8 controls on the front. the chassis is drilled for a 100watt setup but only populated for 50watts.
space for 4 power valves, and 4 preamp valves already. layout is very similar to the superlead with the HV caps between the power and output transformers.
I want to work on this on and off and try a few things out in it. I'll probably build another high gain of sorts.
There are some bits id like to try, like a filtered IEC socket (just to see if it makes a difference). I'd also like to beef the power up to 100watts and try split bias. maybe mix 6550 and EL34 output valves. Maybe use a cathodyne PI a la VHT.
could do a really slow build dairy?
Nephilim
Re: New Amp Build Project
« Reply #1 on: October 08, 2011, 12:59:08 AM »
I've been thinking about learning how to build amps, so it would be great to see a diary to give me that extra drive :)
« Reply #2 on: October 08, 2011, 01:09:11 AM »
Cool. i should probably learn how to do it too! ha.
Nephilim
« Reply #3 on: October 08, 2011, 01:30:05 AM »
Well practice makes perfect! :)
Transcend
« Reply #4 on: October 08, 2011, 08:42:48 AM »
yeah just whack up a wordpress blog and get some good photos in there.
Im also interested about the filtered IEC's its something i've never tried but have thought about.
I actually may do it on my next build
« Reply #5 on: October 08, 2011, 09:10:02 AM »
i might do that first. so i can get a good A/B comparison. best chance to see what difference it makes.
I want to reverse engineer the DC heaters in my Avenger too. maybe.
should get the amp (or amps) today.
2x Laney 50watt AOR protubes.
Transcend
« Reply #6 on: October 08, 2011, 09:16:53 AM »
Ahh i remember discussing these amps.
Are you still abroad?
« Reply #7 on: October 08, 2011, 09:17:55 AM »
nah im back now.
got back on the 4th. but ive been working pretty solid since then. just got home from my first of 7 nightshifts this week
Transcend
« Reply #8 on: October 08, 2011, 09:19:21 AM »
Ill have a good catch up with you later and get all the details.
« Reply #9 on: October 08, 2011, 09:26:39 AM »
nice one
« Reply #10 on: October 09, 2011, 12:04:00 AM »
here it is...
it actually looks cool inside so I'm undecided about what to try.
Nephilim
« Reply #11 on: October 09, 2011, 01:24:19 AM »
I just wondered, I know where you can probably get all the pots and wires for an amp. But what do you actually do when it comes to the circuit boards, etc?
« Reply #12 on: October 09, 2011, 01:32:46 AM »
well if you had all the stuff you could design and etch your own. I've etched boards when i was in high school, but nothing complex.
Or, you can buy various board materials and use eyelets or turrets to wire parts point to point. obviously you can mix and match. just depends on what your trying to build.
http://www.turretboards.com/tut_building_turret_and_eyelet_boards.htm
Transcend
« Reply #13 on: October 09, 2011, 09:58:13 AM »
A great company to deal with if you want no response to your emails!
« Reply #14 on: October 09, 2011, 10:01:03 AM »
haha. ive never tried dealing with them. i posted that link as a guitar to turret board really.
