ground wiring question
Started by mniel8195, January 17, 2012, 11:05:20 PM
mniel8195
hey guys my order is still processing but i have a quick question.  My blackouts were installed in emg wiring.  So i assumer because they were active that the pickups were not grounded.  I pulled out all the electronics and switches and the only thing that was left was a mysterious wire coming out of the body that was heat wrapped at the end so no wire was visible, it was a black wire.  Is this the what needs to be ground to the volume pot or do i need to get a seperate wire to do that?
i had the same thing in an LTD EC-1000. it went off through the body towards the bridge posts.
sounds right.
always best to post a picture.
Yeah, if it looks like it's coming from the direction of the bridge, it's a ground wire.
Nice bit of forethought from the guitar manufacturer.  :)
Quote from: mniel8195 on January 17, 2012, 11:05:20 PM
... and the only thing that was left was a mysterious wire coming out of the body that was heat wrapped at the end so no wire was visible, it was a black wire.  Is this the what needs to be ground to the volume pot or do i need to get a seperate wire to do that?
This wire is almost certainly connected to your bridge. If you have a digital multimeter you can check whether there is continuity between this wire and the bridge (or tailpiece). If so, this wire should be connected to ground, which can be the back of a pot or any other convenient grounding point. This connection is not needed for EMGs, that is why it was taped. Good thing the tech who installed the actives left it in for future use.
juansolo
LTD/ESP when fitting active pups don't neccessarily connect up the bridge ground (it's usually not needed). However the lead is usually still there. Which is nice. But that's what it is.
[url="http://stompage.juansolo.co.uk"]http://stompage.juansolo.co.uk[/url]
