Author Topic: H (RWRP) H  (Read 6360 times)
H (RWRP) H
« on: April 15, 2012, 04:20:13 PM »
Guys, I've got a RWRP Trilogy, and I want to use it between two standard Nailbombs - would this work?  Would there be any effect at all?
Frank
Re: H (RWRP) H
« Reply #1 on: April 15, 2012, 04:37:46 PM »
In terms of phasing, RWRP  pickups are just the same as normal pickups. Reverse winding reverses the phase then the reverse polarity re-reverses it so it's just like adding any single-coil pickup to a HH guitar.
Re: H (RWRP) H
« Reply #2 on: April 15, 2012, 04:43:27 PM »
Yeah, I kinda get that - however, I've heard people mention that the combined tones can be quite difference (pos 2 & 4).
Re: H (RWRP) H
« Reply #3 on: April 17, 2012, 07:01:50 PM »
i heard this too.
i think (but only about 15% sure) the single will have to be NPRW (normal phase, reverse wound). Tim will know I'm sure.
Re: H (RWRP) H
« Reply #4 on: April 17, 2012, 07:57:20 PM »
Thanks, guys - I got this from Tim:
Quote from: His Royal Timness
what you'll need to do is wire the NBs in reverse, ie red/screen to ground and black to hot.
... so I think that I can manage that.
Does anyone know how that will affect my options in terms of clever switching?  Ideally, I'd like to be able to split the NBs on a miniswitch.
Re: H (RWRP) H
« Reply #5 on: April 18, 2012, 12:08:31 PM »
Just splitting both at the same time, using the two sides of a single mini switch?
Switching red and black will govern which coil is switched off when split - green/white will be wired the same either way.
I think the "normal" BKP coil-split wiring with red as hot gives you the slug coil when split.  So with black as hot you'll get the screw coil.
Re: H (RWRP) H
« Reply #6 on: April 18, 2012, 04:07:16 PM »
I've heard banter about tonal differences on this too - one of the new BKP videos on youtube covers this.
Re: H (RWRP) H
« Reply #7 on: April 18, 2012, 06:01:42 PM »
Is it really a big deal?  OK, there's a subtle difference in positions 2 and 4 of a Strat set with an RW/RP middle.
But an HSH set?  It's not as if there's a "classic HSH positions 2 and 4 sound" we've all grown up hearing in our heads.
If they turn out to be out of phase, then swapping a couple of wires will fix it.  Beyond that, I defy anyone to notice anything "different" about the sound.
Re: H (RWRP) H
« Reply #8 on: April 18, 2012, 09:49:56 PM »
Sounds like a challenge, PQ!
 :D
