Author Topic: PRS DGT Adding a 5 way to get Splits in Parallel plus Single coils suggestion?  (Read 7830 times)
DGTer
Folks,
I am looking for suggestions on 2 things.
1) What is the best configuration for my DGT to achieve sounds like on a CU24 Plus having single coils alone.
2) Which are the best suited for this BK pickups. They have to sound full and chimey/straty on Split parallel AND single coil sounds PLUS be able to deliver great humbucker sounds. I hear that asymmetrical pups are best? and a magnet needs to be flipped? The net is overwhelming me with options and wanted to set this straight.
My goal is to keep a 3 way toggle configuration if possible in order to easily flip from neck to bridge in a solo.
I have found a diagram that allows for the a Dimarzio 3 way EP1111 switch and a 5 way 4 pole rotary from stewmac that enables you to have the 3 way for selecting:
1) Full humbucker neck (on up postion of toggle)
2) Rotary switch with any of the 5 sounds selected (parallel, etc) be engaged in the middle position of the toggle,
3) full humbucker bridge in the 3rd toggle position.
But there is NO coil tapping for single coil sounds. Is there a way to keep the push pull tone knob for split tones with the above config? or a better way to achieve getting single coils alone + single coils in parallel (inner and out) + humbuckers that involves less wiring and adding a 5 way rotary?
I've seen a 6 position toggle switch from guitar electronics dot com but not sure if it will allow me to do all I need on its own. it says it is a 2 pole.. is that mean no splits in parallel?
I'd really appreciate someone's knowledge to achieve this as my DGT feels like needing an upgrade of pups and tones...miss the strat in between tones...  and want different pickups because the neck is too boomy on the DGT and bridge is too bright to my taste. Can use a more modern sound too.
thanks all!
Welcome  :)
I've got to be honest, it sounds like you should sell your DGT and buy a Custom 24 with 59/09 pickups...
DGTer
Welcome  :)
I already have a CU24 with HFS/Vintage.. but the DGT's neck and feel is just so great that I want to juice it up to my liking.
Fair enough  :)
You could add push/pull pots to the two volumes rather than have a rotary switch, but I've no idea what would be possible and what the hell the wiring would look like!
DGTer
It will be a ton of work. But may be doable.
What pups do you suggest. I've been looking at the VHII since they are apparently better suited for coil splitting but not so sure it will be the right pup for me. Will that play some modern rock and then do some blues and GREAT cleans? other suggestions?
Mules are always a great option for all-rounders, but if you're going to use the splits I'd go for VHIIs.
blue
DGTer
http://www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/Free-Way_Pickup_Switch.html?actn=100101&xst=3&xsr=49249
this might solve your problem, with no need for a rotary switch
That's interesting. Thanks.
But can you get two single coils at the same time in parallel?
blue
now that i don't know :)
if you go to the instructions tab on the product page, there is a downloadable pdf file with a number of wiring diagrams for it.  should give you a good idea of what's possible with it.
I have a pair of these and love them. they work and sound great, if you can get over the looks. Give you screw or slug coil, series and parallel. All sound different and are worth it.
