Author Topic: Marshall Dsl 100 h new 2012 model  (Read 9736 times)
helderhalen
« on: October 14, 2012, 02:01:31 PM »
Hi Guys
Im about to buy a new amp , i heard about the nem dsl line from marshall site, did someone experimented these head yet? It seems pretty awesome
Thanks
tekbow
Re: Marshall Dsl 100 h new 2012 model
« Reply #1 on: October 14, 2012, 02:14:37 PM »
Don't necessarily think the digital reverb over spring reverb is an ugrade. Sounds more like sexed up cost cutting..
other than that, whats your application? unless you're playing stadiums, save money and get the 40W combo, more than enough wattage for most applications
TheyCallMeVolume
« Reply #2 on: October 14, 2012, 03:18:50 PM »
Should be decent, however they are not made in England like the previous DSL's. Don't know if that makes a difference to you or not, but I personally would rather get a MIE used amp than one made in Asia that's new.
dark order flying V
  • Me with my two custom made Grubisa Flying V's
    • DARK ORDER - Australia's Militant Thrash Metal band
« Reply #3 on: October 15, 2012, 07:54:07 AM »
Hi Guys
Thanks
Just been to the webpage.... its not just the dogital reverb, but more importantly that have replaced the stupid deep switch and VPR/mute buttons with a a low end resonance pot to adjust as mych as you like, like the JVM's have, plus just like the JCM900 have,  a pentode triode switch to reduce the power to 50W.
As a TSL player for the last 11 years, what I really want is the variable effects loop pot like the JVM has
Thrash Metal is my blood
« Reply #4 on: October 15, 2012, 08:12:35 AM »
Great amp, great price, what's not to like? I'd probably still get a used old one, because they sound so raw. But all clips I hear from the new version sound splendid!
jpfamps
    • http://www.jpfamps.com
« Reply #5 on: October 15, 2012, 01:02:58 PM »
The first run of JCM2000 DSLs/ TSLs were one of the least reliable amps Marshall have ever made.
Now, I'm not really into high gain sounds, however I also think these amps sound terrible as well, so I am amazed they are so popular (although they do keep me in business).
This may of course be due to me not really being into the genera on music they are appropriate for.
« Reply #6 on: October 15, 2012, 01:37:00 PM »
If a DSL sounds like this, why would I not be all over it?
http://www.youtube.com/watch?v=1l5KnwZ94Cw
bucketshred
  • Groovy
« Reply #7 on: October 15, 2012, 02:06:15 PM »
Yup, I had a TSL for 6 months from new when I was 18, it blew within 6 months (and never left the house/went above 2) so I PX'd it for a JCM800 which has blown up once in 6 years and is my all time favourite amp!
I did have a 50w DSL for a while and it was a cracking amp for more modern stuff. If you like it, go for it.
GREAT GOOGILY MOOGILY!
« Reply #8 on: October 15, 2012, 02:21:16 PM »
I was just wondering if they might have changed the design a bit. sorted out that notorious bridge rectifier in the filament supply.
The other clever thing they did in the original DSL, was using switching jacks on all the speaker outputs. The connection to ground for the 8ohm/4ohm outputs is switched through the 16ohm only jack. I guess they did this to make it impossible to use the 16ohm output at the same time as the other outputs. The problem there is if the sleeve switch on the 16ohm jack socket gets dirty then it will stop the 4ohm/8ohm outputs working by breaking their connection to ground.
Hunter, thats a good clip.
Digital reverb is what it is. After going out and playing a bunch of reverb pedals it strikes me that it is definitely possible to achieve and really good reverb digitally. Whether Marshall have done that in this amp remains to be seen.
I also think the pentode/triode switch is a bad way to do that power reduction. May as well use a switch that turns off two valves and keep the output running in pentode. Triode mode is changing more than just the overall power, but it's handy if you like the triode sound I guess, which I don't. If it was switching to triode mode and running ultra linear that might be interesting, but if it's just to switch between 100 and 50 watts I think it's a bit of an antiquated idea.
A friend of mine also had a TSL. He never gigged it and used it for home recording (he was an AWESOME player) but it used to be in for repair constantly, hence why when it came time for me to buy an amp I avoided the JCM2000's
jpfamps
« Reply #9 on: October 15, 2012, 03:20:20 PM »
It certainly is on the JCM900.
I've seen several of these where the PCB around the pentode/triode switch has burnt away.
jpfamps
« Reply #10 on: October 15, 2012, 03:22:25 PM »
As I say, not really my bag, but I prefer the sound of the EVH.
There's also been a bit a processing done to that recording........
TheyCallMeVolume
« Reply #11 on: October 15, 2012, 04:01:45 PM »
Tell you what, forget about all these Dual Super Leads and Triple Super Leads, what about the Super Leads?
dark order flying V
« Reply #12 on: October 16, 2012, 04:03:48 AM »
Yuk, the EVH is really disgusting, played one the other day, typical Peavy/fender...
« Reply #13 on: October 17, 2012, 11:25:25 PM »
DSL sounds decent for the money.
