Author Topic: Adding a Middle pickup to my Tele  (Read 2356 times)
PosterBoy
« on: November 11, 2012, 03:25:03 PM »
So I've been thinking about routing out a chunk of wood from my Tele and adding a strat middle pickup.
I have the piledriver set in their currently, which pickup would be a good match, I'm guessing something fairly hot like the Irish tour middle pickup.  Also do I want it standard or RW/RP ?
Re: Adding a Middle pickup to my Tele
« Reply #1 on: November 11, 2012, 05:31:47 PM »
If you want less hum RW/RP. An IT is a good pickup as a standalone middlepickup, but will be overpowered by the Piledriver of course.
PosterBoy
« Reply #2 on: November 12, 2012, 10:37:01 AM »
Would the Piledrivers overpower it, if I was just using it for 2 & 4 positions and never by itself?
PosterBoy
« Reply #3 on: November 12, 2012, 03:16:03 PM »
Is there a difference between middle and bridge pickups apart from the Dc resistance?
« Reply #4 on: November 12, 2012, 04:42:51 PM »
The bridge-IT is hotter then the middle-IT, as with every strat-set.
By overpowering I mean the Piledriver has (way) more output then the middle-IT. If you blend those two, the Piledriver will dominate.
PosterBoy
« Reply #5 on: November 12, 2012, 04:51:13 PM »
So I could need a special middle pickup wound for me then
« Reply #6 on: November 12, 2012, 05:13:06 PM »
That depends. If you want them to balance you need something a little hotter. You could mail the BKP-team for a recommendation.
PosterBoy
« Reply #7 on: November 16, 2012, 02:18:06 PM »
Just got a reply from Ben @ BK and he recommended the Irish Tour middle.
Thought I'd update the thread, for anyone else searching something similar
« Reply #8 on: November 17, 2012, 12:57:36 AM »
Try to fiddle with the height to get the best balance. I hope you'll like the IT.
