Author Topic: Neck Replacement For Seymour Sh-1 in Charvel  (Read 6802 times)
darrenw5094
« on: June 25, 2013, 01:25:15 AM »
Charvel MIJ just had a Holy Diver stuck in the bridge, replacing the SH-4. After a bridge Schaller change, the bridge tone is perfect. Alder body and maple board means, it's fairly bright. The existing SH-1 is ok, i love the PAF style, but it's a bit muddy.
I want to retain the PAF neck tone similar to the SH-1, so i am thinking the Riff Raff or Mule neck.
BTW, the HD is the same volume as the Seymour in the neck......just for future reference. :)
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Re: Neck Replacement For Seymour Sh-1 in Charvel
« Reply #1 on: June 25, 2013, 01:29:22 AM »
In that case the Mule-neck (which is a gem), the RiffRaff wil be a bit bright in this guitar.
Arthurus
  • BKPs: VH-II, Holydiver, Juggernaut
« Reply #2 on: June 25, 2013, 01:46:09 AM »
I don't know the Mule or The Riff Raff, but if you want to tame the highs, consider the VH-II. I have it in the nec position of my Ibanez and it sounds fantastic ! Really pairs well with the Holydiver.
But hey, just my two cents here !
Beards can cure cancer. Like, for realz.
darrenw5094
« Reply #3 on: June 25, 2013, 01:49:40 AM »
Thanks for the replies, i am even looking at the PG Blues neck to match with the Holy Diver bridge.
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
« Reply #4 on: June 25, 2013, 01:52:59 AM »
Just to know: the Mule-neck is very balanced and definitely not too bright.
darrenw5094
« Reply #5 on: June 25, 2013, 01:55:54 AM »
The Mule seems to be the better choice than the Riff Raff.
Maybe the Crawler neck? But the Mule sounds great in my Goldtop Les Paul.
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
« Reply #6 on: June 25, 2013, 09:43:04 AM »
Since that is somewhat of a hotter and fatter version of the Mule neck I can see that working too.
Ahhh the possibilitys...
« Reply #7 on: June 25, 2013, 01:50:55 PM »
You have many options - Mule, Riff Raff, VHII, Abraxas and Crawler come to mind if you want a vintage character. Of the neck pickups I mentioned I have played the VHII (hottest), Crawler (a bit less hot but more vintage character) and Abraxas (vintage character but brighter). The VHII appears to be the tightest in the bass but I have not played the VHII and Abraxas in the same guitar.
Alternatively you could get the Cold Sweat neck which matches very well with the Holydiver bridge (a combination I use), the Emerald neck (a combination much praised here in the forum) or the Holydiver neck (lower output and quite bright).
That has to do with the bridge vs. neck position. Strings vibrate more under the neck pickup than under the bridge pickup so the pickups pick up more signal at the neck position. That's why in most calibrated sets the bridge pickup has more output.
darrenw5094
« Reply #8 on: June 25, 2013, 05:10:31 PM »
So you guys have narrowed it down to the Riff Raff, Mule, Crawler, VHII, Abraxas, Holy Diver, Emerald or Cold Sweat.  :P
Anyway, is it possible that the Seymour SH-1 would sound better than any of the Bare Knuckle range?
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
« Reply #9 on: June 25, 2013, 06:31:17 PM »
Nah.
If you're wanting PAF character I wouldn't get bogged down in considering too many different models.  The Mule, Crawler and Abraxas are all quite similar alnico 4 pickups, the Mule is the most "obvious"/popular choice of those and is unlikely to disappoint.  If you want a brighter but still vintage pickup, go for the alnico 5 Riff Raff.
If you don't want a PAF type, then start thinking about the other models mentioned.
« Last Edit: June 25, 2013, 06:37:31 PM by Philly Q »
darrenw5094
« Reply #10 on: June 25, 2013, 07:29:39 PM »
Probably any of the PAF type BKP will be an improvement over the Seymour.
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
« Reply #11 on: June 25, 2013, 11:18:17 PM »
I have BKP'd all my guitars and can only say they're are really a step up in dynamics, clarity and noteseparation.
« Reply #12 on: June 26, 2013, 01:06:21 AM »
Nah.
I'd look at Cold Sweat neck if you want it less muddy - A5 but a slightly finer wire gauge allows for a more detailed sound
  • Random Solution
« Reply #13 on: June 26, 2013, 03:17:28 PM »
Not a prayer!
Firstly, you've made a great choice for the bridge. The Holydiver is my favourite Rock/Metal pickup for the bridge. Of the neck choices you've been given, I think the Riff Raff and the Holydiver would be too bright and although it's my favourite neck pickup, I think the same may also be true of the Emerald. The Cold Sweat isn't quite as bright so you may get away with that one. The VHII could work well but I'd be making my top three to be the Mule, Abraxas and Crawler. If you want your tone to be darker, thicker and more compressed, go with the Crawler. If you want it to be traditionally PAF, go with the Mule and if you want it between the two in terms of compression and a bit brighter, go with the Abraxas.
darrenw5094
« Reply #14 on: June 26, 2013, 11:16:10 PM »
Not a prayer!
Firstly, you've made a great choice for the bridge. The Holydiver is my favourite Rock/Metal pickup.
Lol dude. I think I bought it from you.  Mule seems to be  thw way to go.
Mule - Les Paul
VHII - PRS CU22
Emerald - Les Paul
