Author Topic: So i got a painkiller yesterday  (Read 7329 times)
Toe-Knee
    • DIY Audio
« on: July 21, 2013, 09:33:10 PM »
It's not really what i expected. It's a bit too much of eveything for my tastes.
 Too much saturation (this is coming from an EMG user) WAY too much low end and the highs are kinda fizzy. Kinda reminds me of a duncan invader.
I'll give it a few days and see if my opinion on it changes.
I was hoping for a classic metal kinda sound but so far all i've managed to pull from it is modern garbage :(
It looks like I may end up with a Miracle Man in my designated BKP guitar.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
  • Random Solution
Re: So i got a painkiller yesterday
« Reply #1 on: July 21, 2013, 10:03:41 PM »
I've never tried a Painkiller but I've always imagined it as a lot brighter and thinner than an Invader due to lots of highs and high mids, while I find the Invader to be fat and dark with more lows and low mids. From the sound of it, you will much prefer the Miracle Man.
Toe-Knee
    • DIY Audio
« Reply #2 on: July 21, 2013, 10:10:32 PM »
I've owned a miracle man well a few of them in the past and know i like them. I just took a chance on this really out of curiosity. I too figured it would be fairly bright and thin.
darrenw5094
« Reply #3 on: July 21, 2013, 10:27:13 PM »
Pickup height?
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
Toe-Knee
    • DIY Audio
« Reply #4 on: July 21, 2013, 10:34:19 PM »
Pickup height?
I've messed with the height and pole pieces a fair bit. I'm going to keep on tinkering. As well as trying some different strings before giving up.
At first i was quite liking the sound before i switched to other guitars loaded with pickups from various other manufacturers and noticed how much it was lacking.
I think maybe it just isn't the right pickup for the guitar. I'll see how it works recording tomorow maybe as that is the primary use of this guitar anyway.
JimmyMoorby
« Reply #5 on: July 22, 2013, 01:26:17 AM »
Also the exact opposite of what I expected you to say actually!
Didnt you say have a soldano?  How does it sound through that out of curosity?  From what others have said id imagine that really would sound like well..... painkiller judas priest type tone.
Fizzy could never be a good sound though!
« Reply #6 on: July 22, 2013, 02:44:29 AM »
the triple magnet configuration makes it quite loud and sensitive
try setting it very low and far from strings and then you try it a little higher
it shouldn't be too bassy in low string height setup
it helps taming the mids too, so it should sound less harsh
« Last Edit: July 22, 2013, 04:51:55 AM by Eric Hellstyle »
braintheory
« Reply #7 on: July 22, 2013, 04:01:00 AM »
What kind of guitar is the Painkiller in?
You might also like the Lundgren M6.  It's a fantastic pickup.
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Mesa/Boogie Mark III Coliseum
Mesa/Boogie Mark IIC+
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Wizard Modern Classic
Toe-Knee
    • DIY Audio
« Reply #8 on: July 22, 2013, 04:34:04 PM »
I've got it a little more to my liking.
Here is a quick clip. Still not ideal but its better.
https://dl.dropboxusercontent.com/u/9807181/Recordings/Grind%20redux%20PK.mp3
and before where i still wasnt happy with a duncan distortion
https://dl.dropboxusercontent.com/u/9807181/Recordings/Grind%20redux.mp3
Toe-Knee
    • DIY Audio
« Reply #9 on: July 22, 2013, 04:35:53 PM »
Clip added. I'm gonna restring it with some different strings at some point and try it in standard to see if i can capture those JP tones better.
Its a jackson DKMGT. MIJ Alder i believe with a maple neck/rosewood board.
The clips are with the pickup about 1cm away from the strings
« Last Edit: July 22, 2013, 04:37:53 PM by Toe-Knee »
  • Random Solution
« Reply #10 on: July 22, 2013, 05:08:58 PM »
Due to the references to a Painkiller being a bit 'ice-picky' you see around the forum, I never would have thought of trying a Painkiller in that guitar. Having said that, your clip is sounding pretty good if you're after that hard, aggressive tone. The Miracle Man has more body to it for sure but it's also smoother and maybe that's not what you're after with this guitar.
Toe-Knee
    • DIY Audio
« Reply #11 on: July 22, 2013, 05:15:27 PM »
To be honest i only went with it as i got offered a trade for a set of pickups i wasn't using. Ideally i'm aiming for an exodus type tone from exhibit B Tim says the blackhawk will deliver. I know from past experience that the Aftermath can do very exodus like tones too so that may be the ticket.
With regards to the MM i have a lot of experience with it and i think it could possibly work for what i want in this guitar if i use an OD but i try to avoid that where possible as my amp can handle anything i throw at it without one usually.
« Last Edit: July 22, 2013, 05:50:38 PM by Toe-Knee »
GuitarIv
« Reply #12 on: July 22, 2013, 06:37:27 PM »
If I'm honest I really like those clips, and the one with the Painkiller more than the Duncan. I have experienced a huge low end with mine as well, but it's in a Jackson Fusion with a Mahogany body, Maple Neck and Rosewood Fretboard + the shorter 24.75 inch scale, so a rather dark guitar. How do you mean it sounds fizzy?
Toe-Knee
    • DIY Audio
« Reply #13 on: July 22, 2013, 07:36:27 PM »
I  had to  lower  my presence  to 2  and treble  to 3  to get that tone.  with  the distortion I  had then both sound 7
« Reply #14 on: July 23, 2013, 05:10:47 AM »
the c-bomb sounds more like modern exodus, although the aftermath and painkiller help with the scratchy picking
what amps are you using?
