Author Topic: VHII or Crawler or indeed other  (Read 7543 times)
keen007
« on: January 27, 2015, 09:27:28 PM »
Getting closer to making a decision now. I have a Les Paul Custom with an ebony fretboard which seems to flatten warm mids. The tone I am after is like Gary Moores on Cold Day in Hell. Warm mids and woody with slightly more than PAF heat. Will the VHII set retain the Les Paul identity. Will the neck give me a "SD Jazz " tube like smooth tone or am I better off with say a Cold Sweat in the neck and a Mule or Crawler in the bridge. Don't have the money to get this wrong. :undecided: I know that this is almost impossible to do by comment but would very much appreciate guidance.
Re: VHII or Crawler or indeed other
« Reply #1 on: January 27, 2015, 09:55:12 PM »
A quick summary:
Mule - open and dynamic 59 PAF - AIV-magnet
Abraxas - hotrodded Mule - more mids, less topend and compression than the Mule - AIV-magnet
Crawler - über-Mule - juicy, thick tones, round, but not dull topend and more compressed than the Abraxas - AV-magnet
Crawler can be a hit or miss in Les Pauls, but a bright one could benefit from it's bold tones.
VHII can be a hit or miss in a Les Paul: hot classic PAF, quite balanced, but compared to the Mule, more bass. Nearly uncompressed, very vocal, but also - to my ears - a little dry. Screams when you dig in, because it's a very touchsensitive pickup. The VHII performs most of the time well in alder/ash bolt-on guitars. In Les Pauls it's not everybody's darling.
My recommendation - based on your description - would be: Abraxas-bridge/Mule-neck.
keen007
« Reply #2 on: January 27, 2015, 10:08:51 PM »
Thats really useful and comprehensive info and helps me make the distinctions I have been after. Thanks very much for this response.
BigB
  • Let's rock !
« Reply #3 on: January 28, 2015, 12:39:43 PM »
I assumed you meant "less topend and more compression" ?
Actually AV bridge / AIV neck. I find the Crawler bridge to be more of an über-RiffRaff FWIW
@keen007: I don't have much experience with LP Custom, but the few I played were mostly fatter / darker than Standards, so the extra warmth and fatness from the Crawlers might over the top here - Crawlers really shine when you want to fatten up a thin/bright guitar.
Also keep in mind that
1. despite the vintage specs Mules (and RiffRaff) are far from shy... Not as much output as their hotter brothers for sure, but still enough to push your amp, so switching from say Nailbombs or Crawlers to Mules or RiffRaff doesn't require much adjustements to my settings (FWIW when it happens live I don't even bother adjusting anything), and
2. it's easier to filter out highs and add some compression than to remove compression or add missing top-end.
The Mule neck will deliver smooth vocal tones while keeping enough clarity / top-end to cut thru.  The Mule bridge is quite bright (not a bad thing in a fat guitar) but fattens when you roll down the tone pot. If you want a bit more punch and focus, the RiffRaff bridge (AV, late PAF / early Patent N° specs) might be a good candidate, and FWIW the RR bridge / Mule neck is a well-known, working and quite versatile combo, or if you want to keep the highly organic vibe of the Mule but with a bit more push and compression (and a bit less high end) you can try the Abraxas bridge / Mule neck as telerocker suggests (disclaimer : no personal experience with the Abraxas and I don't know how well it will balance with a Mule neck).
Now don't forget to ask the BKP team for more advices... They do know their stuff.
« Reply #4 on: January 29, 2015, 06:22:28 PM »
Yeah less topend and more compression.
I was talking only bridgepickups. You're correct: the necks of those three related pickups are all AIV.
I don't think there's a big mismatch in a Abraxas-Mule-neck combination. Mule- and Abraxas-neck are equally hot, though the Mule uses 42 AWG plain enamel wire and the Abraxas 43 AWG plain enamel wire, so there is a slight difference between those neckpickups.
« Last Edit: January 29, 2015, 06:29:02 PM by Telerocker »
BigB
  • Let's rock !
« Reply #5 on: January 31, 2015, 11:12:40 AM »
Assuming a same DC resistance, 42AWG vs 43AWG does make a difference wrt/ output level.  I just re-checked the specs for the Mules, Abraxas and Crawler and I fear the Abraxas bridge will overpower the Mule neck, and the Abraxas neck will be too hot for a LP Custom IMHO (it's almost as hot as a Crawler neck, same wire same gauge same magnet).
« Reply #6 on: January 31, 2015, 12:20:12 PM »
I don't think the volumegap will be big.  By example, Chris from BKP uses a Nantucket/Blue Note-neck combo. When I go from my Crawler-bridge to IT-neck the volumedrop is not very big too.
keen007
« Reply #7 on: February 01, 2015, 07:16:47 PM »
Plenty of food for thought here. Thanks for the input folks.  Just took classics out and put the burstbuckers in just for reference. The classic plus in bridge was good in bass and lower mids but was brash in higher mids, unusual as sounds acceptable in my Traditional. Burstbucker in comparison just seems boring in every part of EQ.
Seems to be the ebony fretboard which is the changing influentual factor which is a shame as it also makes the guitar very fluid on action.
BigB
  • Let's rock !
« Reply #8 on: February 02, 2015, 12:11:11 PM »
Seems to be the ebony fretboard which is the changing influentual factor.
Is your Custom a mahogany top or a maple top one ?
« Reply #9 on: February 02, 2015, 05:40:29 PM »
Burstbuckers are imo quite mediocre.
Alex
« Reply #10 on: February 03, 2015, 09:59:00 PM »
I can only comment on the VHII neck. It is warm and clear, as you say, BUT I don't feel it sounds like the Gary Moore song you say. I had it in my ESP Eclipse which also flattens the sound a bit (probably the ebony fretboard). I kind of felt it was a bit flat and didn't have enough bite/spark. Not like the SD Jazz.
I think your best bet is to write directly to the BKP team. I wouldn't be surprised if they recommend the Riff Raff or Mule set for that tone.
« Reply #11 on: February 04, 2015, 10:07:53 AM »
I would not go for the VHII set in this case. The bridge pickup will not add warm mids - it is a rather punchy and aggressive beast and may be too much for a bright guitar with an ebony fretboard. The VHII neck is a nice pickup, also very punchy and can sound very aggressive if you dig into it.
If you are going for a SD Jazz like tone, the Holydiver neck may be the best option. It is my favorite BKP neck humbucker so far. The Crawler bridge should be a good match to it.
seancorker
« Reply #12 on: February 06, 2015, 11:00:59 PM »
I'll apologise in advance for throwing a curveball in but I'd been looking for a pickup for my Kramer Nightswan for what seems like eons. 'Swans are mahogany body, maple neck and ebony fretboard axes with Les Paul scale necks. The problem I had was dealing with the flubby mahogany low end and brittle top ebony boards give you. The solution after trying 3 different BK's was "The One" by Lundgren. If Carlsberg built pickups............
Nothing sounds like a Skyline GTR ...... but BKP comes close!
darrenw5094
« Reply #13 on: February 07, 2015, 12:54:06 PM »
BKP don't like peoples mentioning 'other' pups on their forum above their own.  :wink:
BKP: Abraxas - Les Paul
Holy Diver - Charvel
Mule - Les Paul
Rebel Yell - Les Paul
VHII - PRS CU22
Emerald - Les Paul
Warpig - Caparison Horus
« Reply #14 on: February 07, 2015, 02:12:19 PM »
If you can't find a tight BKP that works for a mahogany body/ ebony board, I don't think the pickup is to blame.
