At last the EVM12L is back
Started by HJM, August 01, 2006, 08:56:24 AM
HJM
Tim
Jesus, those look seriously heavy duty :twisted: !
Tim
I saw an ad for them in Guitar World. They are scary speakers! Can you imagine the weight of the cab! It'll be worth it though  :twisted:
only 300w per speaker? what a wuss...
:roll:
OD-Black_Fire
I'm guessing what I heard about having a 100 watt amp and a 600watt cab will make your amp blow up was bullshitee, right?
downrodeo
Definitley. A 100 watt amp and 50 watt cab...not so good. A 600 watt cab would be no problem with a 100 wat amplifier driving it because the 600 watt rating of the cab refers to HOW MUCH input wattage it can handle; as in, from an amplifier.
Dakine
Darn things cost more each than a half decent 4x12 cab though.
I had a Rivera 2x12 with them in and there was no way it could be moved by one person alone, and it was tough with two people
A 4 x12- think I'll pass on that
I think Jake E Lee used to use them too
OD-Black_Fire
But the true question is, did the tone make up for it?
Skybone
QuoteThat's a lot of speaker!
More like "That's a lot of speaker magnet!"...
Imagine a cab with 4 of those suckers in... It'll fly in the face of any manual handling regulation ever written! ;)
Bibble.
Quote from: OD-Black_FireBut the true question is, did the tone make up for it?
Nah - swapped them out for a pair of Celestion Sidewinders
Similar in some ways and has a bit more of that British sound as well
HJM
Quote from: OD-Black_FireI'm guessing what I heard about having a 100 watt amp and a 600watt cab will make your amp blow up was bullshiteee, right?
We're talking guitar valve amps not PA! Clipped tranny amps can kill speakers, clipped valve amps sound great...
HJM
Each driver weighs about 16 lbs ...
Now I want a set!!!
