Does anybody use tonepros bridges here?
Started by 5F6-A, October 11, 2007, 09:10:27 AM
5F6-A
I'm thinking about using one ( ABR-1 type ) in my LP. Most people like them but some claim it takes away some mids and lows...
any info?
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
They work great for me
Dont see how it might rob mid and low tones
If you left the grub-screws unlocked its no different to a regular bridge
And locking them just tightens everything up
BigK
Ive got them on quite a few guitars and I think there great. If anything ive experienced the opposite of what your describing as it physically locks your bridge so it acts as one big piece of metal so to me that can only increase the resonance and sustain.
PRS Tremonti - PRS Silverburst 594 - Ibanez RG550EX, RG570 & RG721FM - LTD SC 500 -  Schecter 006's - EVH 5150III 50w into custom Zilla Vert 2x12
Quote from: FELINEGUITARSDont see how it might rob mid and low tones
+1
I'm a bit sceptical about the claims that they increase sustain, but they certainly don't have any detrimental effect on the tone.  After all, they're just regular Gotoh parts with a couple of little grub-screws added.
they do in theory increase sustain - anything thats stops helps to stop unwanted vibration will do that, but we dont really need much more sustain anyway!!
I think they just make the bridge transfer string energy slightly more effeciently due to it all being locked togther as one unit, but it should be held quite firmly under string tension anyway
The best bit is that your bridge doesnt fall off or move slightly when you change all the strings or abuse your guitar!
I like them but i think they are a bit overpriced for the small benefits they give, so not really necisarry - but why not have them if you can afford them
Quote from: WezVbut it should be held quite firmly under string tension anyway
Well yeah exactly, that's why I'm sceptical.  It's pretty much impossible to move parts under string tension, unless you whack them with a hammer or something.
I've used the TonePros screw-top locking studs for wraparound bridges several times.  They're great for stopping that annoying issue of the bridge tilting forward due to loose-fitting studs, but I don't notice any difference at all in tone or sustain.
5F6-A
Quote from: Philly QAfter all, they're just regular Gotoh parts with a couple of little grub-screws added.
I thought the whole bridge was made to higher specs by tonepros and not just the saddles....
ToneMonkey
Quote from: JackBauerIve got them on quite a few guitars and I think there great. If anything ive experienced the opposite of what your describing as it physically locks your bridge so it acts as one big piece of metal so to me that can only increase the resonance and sustain.
Jack - Didn't know you could access this forum from prison  :lol:
Quote from: 5F6-AI thought the whole bridge was made to higher specs by tonepros and not just the saddles....
I must admit I haven't got the ABR-1 version, but the two (or four, if you count the wide and narrow posts) Nashville models TonePros make are definitely modified Gotohs.
And I'm pretty sure Gotoh do make an ABR-1 with saddles that won't fall out, just like the TonePros one.
samoth2
Quote from: ToneMonkey
Jack's not in prison, Keifer is  :)
5F6-A
I've ordered one I'll keep you posted!!
I am using the tone pros studs on a through neck SG i am building at the moment.  Its having a schaller wraparound bridge and hopefully the tonepros will stop the bridge tilting from string pull as they can with wraparounds.
Quote from: WezVI am using the tone pros studs on a through neck SG i am building at the moment.  Its having a schaller wraparound bridge and hopefully the tonepros will stop the bridge tilting from string pull as they can with wraparounds.
They'll definitely stop the bridge tilting - that's the best thing about the TonePros studs.  But if manufacturers engineered their parts a bit more precisely, the tilt problem wouldn't be there in the first place - I have a couple of Pigtail bridges, with Pigtail's own studs, and they don't tilt at all.
(Must see pics of this SG, Wez!  :) )
not far along yet
its a john birch inspired build.  wait till you see/hear the pickups for it!!
