Quote from: kellarCheck out Visual Sound. They have revamped their entire line and I am itching to try them out. The route 66 and jekyll and hyde are great pedals.
Visual Sound make my all time fave pedal, and if will cover your Chorus/Delay/Echo needs all in one box.
The H20, well made heavy duty construction. Very musical sounds obtainable with just a bit of tweeking, then set and forget.
If size is every an issue, I really like the tiny Guyatone Delay.
Also you said not crazy about Boss, but to be true, the Combo Reverb Delay, the dark grey one, I think maybe it's called RV-X, where X is a number is the swiss army knife box for those with amps without reverb. When I use a non-reverb amp, I can dial in some reverb, when I play through my ampeg with the installed accutronics tank, I dial it in as my 3rd delay pedal. (OK so I like Echo, what's so wrong? LOL)
Another GREAT chorus that I use nearly all the time is from the Univibe guys, It's call the Dunlop Univbe Chorus. This stomper set slow and subtle is killer.
