Best Noise Gate
Started by Valisch, March 09, 2012, 07:37:25 PM
Valisch
       Ok so I'm looking for a noise gate pedal that will help quiet my incoming Lee Jackson Metaltronix M-1000 head that i just won on eBay :D  It seems to be a very noisy amp from what i hear.  So I figure I'll need a noise gate.
Let it be known that I have never used a noise gate in the past so it can't be overly complicated. Also would it be better to run it in front of the amp or in the effects loop, or both?
-{Twisted Sinister Serenade}
Madsakre
Boss Noise supressor. Tried, tested and used by many.
Cattlepress
Toe-Knee
I used to have the Boss NS2 it was alright but it wasnt the best.
I now use a diy MXR smart gate which is a heck of a lot better.
My issues with the NS2 was that it opened and closed quite slowly and also even on max supression it didnt remove all the noise just the majority of it and i actually have a fairly quiet amp.
[url="http://www.backline.tk"]http://www.backline.tk[/url]
Non Biased Guitar Forum
[url="http://fret.boards.net"]http://fret.boards.net[/url]
Alex
I have a Boss NS-2.
I feel the Boss is great when it's in front of the amp, where I swear by it, but I feel in the loop it doesn't work very well (Toe Knee has described the problems in the loop. If your amp is noisy, then it's not a good choice. In my case, my amp is rather quiet and the Boss works great to remove the noise from pedals and pickups, even single coil hum. To be fair to it, the NS-2 is not designed for the effects loop in the first place (according to Guitarist).
Toe-Knee
Quote from: Alex on March 09, 2012, 09:26:35 PM
I have a Boss NS-2.
I did find it a lot better in front of the amp and the loop feature of the pedal itself was great for running noisy OD's and such through.
Valisch
I do like the Idea of the looping option. anyone have experience with the ISP Decimater pedals? I've heard good things about them too.
Toe-Knee
The ISP is great if you are playing really modern metal but i find for some stuff it is quite heavy handed with the way it gates which can be really annoying at times.
But the actual noise supression it offers is fantastic.
are there any pedals out there that are pure gates and don't do any kind of filtering?
Valisch
http://www.americanmusical.com/images/descimages/ISPDECIMATORG_HookUpDiagram.jpg
Would having the pedal set up like this add to its reduction capabilities since its both in front and in the effects loop of the amp?
Toe-Knee
yes it would.
The way that works is in front of the amp it removes guitar/pedal noise and then the section that goes in the loop removes thermal hiss & general preamp noise that you get with valve amps.
Its pretty clever and a great setup.
MAJ Meadows SF
ISP Decimator all the way. The G-String model is extremely flexible.
ENGL, A-PIG, PK, MM, CS, C-Bomb, custom and customized guitars; on a never ending tone quest
enuenu
I've got an ISP G String and it works well and is simple to use.
Attica!
I own the NS2, and I have it wired to supress the noise in both the loop and infront of the amp in a 4-way style wiring. It does the job, but I'm considering trying out the MXR Smart Gate, which I've heard is meant to be very good.
Toe-Knee
Quote from: mbchepburn on March 11, 2012, 12:35:19 PM
The smart gate is a great upgrade from the NS2
Attica!
Quote from: Toe-Knee on March 11, 2012, 01:22:26 PM
With the NS2 it's known to suck tone, but with the MXR, I hear that it only shuts off sound when not playing, which apparantly makes it a true gate, as to the NS2 which supresses the noise at all times. If you follow my drift? Thing is, how would I hook it up to gate both in front, and the fxloop of the amp? Or would it require 2?
