Thanks, I appreciate the reply and your ideas
Actually the Celtic Frost albums were recorded with an IC-50 Iceman (the cheap bolt-on neck version) with the stock pickups (probably V2s). I don't know what Sodom and the others were recorded with. In general though I worry that if I get a MM I will have two guitars with very hot pickups and not a lot of choice in tones. The HD is tempting but elsewhere here I have read bad reports with them in SGs, and the same with Crawlers and A-Bombs (although the latter is more mixed). Given that I will eventually put the A-Bomb in something else for hardcore purposes (it's excellent for that) what I think I probably need is a pickup that (1) has an excellent reputation in SGs (so far all reports with both CS and MM in SGs are excellent) & (2) can handle the spectrum of rock and metal tones not covered by my other pickups. With my Explorer I can tuned it up to Eb or even E in a pinch (perhaps with the Dunlop Heavy Core 11s set) but mainly I am using that in D standard to C standard (and maybe drop C if needed). I have the really brutal death metal stuff covered with that pickup. I would however like a pickup that can stretch into Celtic Frost and Sodom territory as well as covering stuff like the Sykes era Thin Lizzy sound and even Iron Maiden, so I am definitely leaning toward the Cold Sweat, although this is the third time now that I have been tempted by the Miracle Man and I'm sure I will get a set of MMs one day in the future, perhaps in a Les Paul or even an F-spaced one in something like a Jackson Soloist.
The one thing I've learned out of my first BKP purchase (the CS/NB combo) is that hoping to cover every style I want with one guitar is a complete pipe dream. I think that made it very difficult for BKP to recommend a pickup combo to me too. I think I need a few guitars - even if a couple of them are just upgraded cheapies like Epiphones for stuff where the pickup 'takes over' due to its high output) - to cover all of the styles I like to play.
Thankfully I am not too obsessed with the blues - and if anything my interests there are more covered by my acoustic dreadnaught - that I need a vintage pickup guitar
at the moment GAS :?
EDIT: I've always been curious about the Slayer=EMG comments because I don't remember it that way (and I'm old). EMGs I thought came in when they started using ESP guitars, which was later than Metallica. According the following long-winded bunfight over at the SD forum it seems that the early stuff was done with DiMarzios back when they used BC Rich guitars (before it was sold and became rubbish).
http://www.seymourduncan.com/forum/showthread.php?239150-SLAYER-question-What-pickups-were-used-by-Kerry-and-Jeff-on-Reign-in-BloodEDIT:
I sent another email to Ben with a link to Celtic Frost's 'Dethroned Emperor' from the Morbid Tales album and basically stating that that tone was the heaviest one I am looking to get out of this guitar:
QuoteI am gravitating toward the matched set idea, having had a very positive experience with the Warpig set.
Given that I have a very powerful amp with a strong mid-range cut even with the mids turned right down (a Peavey 6534+), and a guitar with very pronounced mids (an SG Standard) a more scooped pickup would match up well. At the moment I just have way too much mids for anything other than hardcore.
If the Cold Sweat bridge works very well in SGs then I am tending toward that. The only thing that has ever had me a little concerned with the CS is that advice regarding mid-range (in terms of output) pickups in SGs. I'm assuming that was more in regard to alnico pickups? As I said from an output standpoint the alnico Nailbomb has been fine, and not muddy at all. It's just very hairy and chainsaw like, which is amazing for playing hardcore of course but doesn't suit a lot of other stuff.
The stuff that I would be playing on the more 'extreme' end of the sound spectrum is Celtic Frost. The way I approximate that sound with the Nailbomb is to roll the tone knob right back. I also find that the CS neck sometimes gives a better Celtic Frost sound than the Nailbomb even when rolled back, although it's not quite right. If the CS bridge is closer in sound to the CS neck but with some of the qualities of the MM it might work well for that. The actual rig used by Tom G Warrior was the cheapest (bolt-on neck) version of the Ibanez Iceman (the IC-50) through a tube screamer (which I have) and a JCM800, with the standard pickups in the Ibanez, which were the Super 70 (maybe these were also called Flying Fingers?) or V2. I'm wondering if the Cold Sweat could *approximate* this sound (even if it needed a 6-band EQ before the tube screamer)? Other than that I think the sounds I want from this guitar are a bit of a no-brainer for the CS: early Judas Priest, early Slayer, early Ozzy, basically a whole heap of late '70s and early '80s metal sounds (before the EMG era). I'm worried that I might end up with two guitars with really hot pickups (i.e., this one and my Explorer and the Warpigs) plus a punk axe (whatever I put the Nailbomb into) and nothing that can cover these metal styles ranging from Scorpions to the early German thrash bands.
Do you think the CS can get this range of sounds, or do you think they are right out its range?
Here's Ben's reply:
Quote from: Ben from BKPHi David,
Yes the Cold Sweat bridge works well in SGs. The Cold Sweat bridge is quite different in design to the neck - the main difference is the magnets. If you need scooped mids, clarity and versatility, then the CS bridge will offer that. I listened to the clip - no problems there. Also fine for 70s/80s hard rock/metal.
Kind Regards,
Ben
Following Ben's reply and what I have thought about and read here I think I'm going to put an order in for a Cold Sweat bridge so that I have a matching set. I've joined the 'calibrated set' club with two sets now, a Warpig set and now a Cold Sweat set. I may install just the A-bomb in the bridge of another guitar with one pickup (e.g., a Les Paul Junior or SG Junior, or a Kramer Baretta) or if it has two pickups I might eventually get a matching Nailbomb set. In this particular guitar I found that the Cold Sweat neck and A-bomb did not match that well, just because the A-Bomb was so punkish and the Cold Sweat is so smooth. They feel like you should be playing different styles with them. The bridge never felt right with this neck pickup as the neck pickup does not suit hardcore at all.
1 x 6 String Cold Sweat humbucker - Covered Bridge
Bridge Spacing: 50 mm
Conductor: 4
Leg: Long (1/2")
Cover: Chrome
Etch: Bare Knuckle Pickups Etch
